my pc is on top of my desk. do you think vibrations will travel up the arm into the mic will be a problem? my desk is wood if that matters.
arm
https://www.ebay.co.uk/itm/Studio-Broadcast-Mic-Desktop-Microphone-Suspension-Boom-Scissor-Arm-Stand-Holder/222643558362?epid=2240780921&hash=item33d69717da:g:8isAAOSwAypZuPhX
mic
https://www.ebay.co.uk/itm/Behringer-XM8500-Ultravoice-Dynamic-Vocal-Handheld-Microphone-600-Ohm/322867479288?epid=1827292269&hash=item4b2c66c2f8:g:Ki8AAOSwEOpaAH0B
also what type of usb cable does the Behringer UMC22 U-PHORIA use?
thanks for your help
https://linustechtips.com/topic/941219-microphone-question/
Im pretty sure you will be fine for vibrations. The boom should cancel it out.
The mic looks lime it uses XLR, not USB.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
https://linustechtips.com/topic/941219-microphone-question/#findComment-11474409
the Behringer UMC22 U-PHORIA is the USB Audio Interface i am going to use with it. i was asking what usb cable the USB Audio Interface uses in case i need to buy a longer one.
https://linustechtips.com/topic/941219-microphone-question/#findComment-11474423
