With the recent Intel trends, I would really like to see direct die cooling make a comeback, there's just something about seeing a bare CPU, granted you won't see it when the cooler is on anyway, it's just an aesthetic thing I like.
Now, there's the risk of cracking the die with uneven pressure like GN pointed out, but I think that could be fixed with pads to take some of the pressure off the die, like you'd see in old Athlon CPUs
AMD Ryzen 5 5600 | MSI B450 Tomahawk | Corsair LPX 16GB 3000MHz CL16 | XFX RX 6700 XT QICK 319 | Corsair TX 550M 80+ Gold PSU
https://linustechtips.com/topic/940822-direct-die-cooling/
I don't think you understand how horrible pads are for heat transfer.
It would literally be 10x worse than a regular non-delidded CPU using toothpaste.
And direct die cooling is already being done by plenty of people, there is no "comeback".
There are special brackets to prevent damage from pressure.
There are no 1151 brackets though because the socket is taller than the die and few people are willing to shave off part of their motherboard to make it work.
https://linustechtips.com/topic/940822-direct-die-cooling/#findComment-11471094
I think @xFluing was talking about placing pads on the pcb in order to transfer the pressure, so they like wouldn't and probably shouldn't be placed on the die.
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
https://linustechtips.com/topic/940822-direct-die-cooling/#findComment-11471102
Just now, Jonas_2909 said:
I think he was talking about pads in order to transfer the pressure, so they like wouldn't and probably shouldn't be placed on the die.
Exactly
@Enderman these are the pads I'm talking about
https://linustechtips.com/topic/940822-direct-die-cooling/#findComment-11471104
3 minutes ago, xFluing said:
That's what I thought of... xD
My gear:
#PCMasterrace
https://linustechtips.com/topic/940822-direct-die-cooling/#findComment-11471115
