Hello, I want to ask that does SLI doubles maximum resoluton. I have one gtx 960 4g (max res.: 5120x3200), and I want to have a triple screen setup in such a way that the middle screen is a 21:9 (2560x1080), all together would make up 6800x1080. Here another 960 would only cost 40k, but a 1060 could go up as 110k, however that can handle that resolution. (I play simulators, not graphic hungry titles) Thanks!
https://linustechtips.com/topic/939655-sli-maximum-resolution/
sli doesn't affect max resolution at all, thats determined by the ports on the card.
The max resolution on the card is per monitor, you can have a highercombined resolution.
You can drive your wanted monitor config off one card if you want.
https://linustechtips.com/topic/939655-sli-maximum-resolution/#findComment-11460447
SLI doesn't necessarily "increase" your maximum resolution. It more so boosts the performance of the first GPU. The more GPUs you run in SLI, the easier it will be to run multiple high resolution displays. You could run your setup off of one GPU. It would strain your 960 quite a bit, but a 1060 shouldn't suffer too much.
http://www.nvidia.in/object/sli-technology-multimonitor-in.html
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/939655-sli-maximum-resolution/#findComment-11460458
You can run the surround setup as the that's a max res per port, depending. You main concern is getting surround to work with different horizontal resolutions.
Unless you mean just running 3 monitors and not actually doing surround. As 960's are gonna struggle with that, unless the games are old or easy to run.
https://linustechtips.com/topic/939655-sli-maximum-resolution/#findComment-11460835
