Now that graphics card prices are coming back down, I've been looking at upgrading from my ancient 280X. For gaming, I play at 1080p, but I want to have absolutely every option set to Ultra without dropping below 120FPS. I also have a Kraken x62 and G10 bracket that will be handling cooling duties, and I'm firmly against NVidia business practices. So I'm wondering what the LTT community recommends between:
RX580
Pros:
  • Cheapest option by a country mile
  • Typically smallest cards
  • Low TDP
Cons:
  • Weakest option by a country mile
  • GPU die and memory are separate units to cool
Vega 56
Pros:
  • GPU die and memory are together
  • Significantly more powerful than RX580
  • Not quite as expensive as Vega 64
Cons:
  • Gimped compared to Vega 64
  • Considerably more expensive than RX580
Vega 64
Pros:
  • Most powerful option
  • Not much more expensive than Vega 56
Cons:
  • Most expensive option
  • Highest TDP to manage
Any opinions or advice would be appreciated, thanks!
https://linustechtips.com/topic/939264-1080p-advice/
That the GPU and memory are separate on the 580 isn't a bad thing, GDDR and flash memory in general wants to be pretty hot to work right.
I don't think the 580 will put you at ultra in everything 120fps+ so the Vega cards are your best options unless you want to buy a used R9 Fury or 295x2. I'd get the 56 and flash it to see if you can get a 58 or even a 60
Builds:
https://linustechtips.com/topic/939264-1080p-advice/#findComment-11456792
Realistically speaking depending on the game you kinda have no other option but the V64 and even so the 1080 Ti is cheaper and more senseful.
I do want to note though that truth be told the best would be the V56 if you can find one that's not overpriced (as the 1070 Ti often is a pretty much better deal) and understand that Ultras are idiotic to chase:
Either ways if you do have all this $ to burn I reinforce that the 1080 Ti is unbeatable in price-to-performance on the highest end.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/939264-1080p-advice/#findComment-11456822
Even with AMD's top of the line Vega 64, you might not always get 120 fps minimum with everything maxed, not on modern AAA titles anyway.
The only card that will do that for you is the 1080 Ti, but since you're against Nvidia products...
1) Gaming Rig: https://pcpartpicker.com/list/TZskD2
CPU: Intel Core i5-4690K @ 4.2GHz OC | Motherboard: Gigabyte Z97N-WiFi ITX | RAM: 2x8GB DDR3-1600MHz G.Skill Ripjaws X-series | GPU: EVGA GTX 1070 Ti SC @ 1817MHz OC
PSU: EVGA 650W G2 80+ Gold | Case: Phanteks Enthoo Evolv ITX | Cooler: Cooler Master Hyper 212 Evo w/ Noctua NF-F12 Fan | SSD: Samsung 850 EVO 250GB | HDD: WD Blue 2TB
Monitor: Dell S2417DG 1440p @ 144Hz w/ G-Sync | Speakers: M-Audio Studiophile AV40 | Keyboard: Corsair K65 Compact Cherry MX Red | Mouse: Logitech G402 Hyperion Fury
2) Digital Forensics Rig: https://pcpartpicker.com/list/sWV7w6
CPU: 2x Intel Xeon E5-2650 v3 @ 2.3GHzMotherboard: ASRock EP2C612D16-4L RAM: 8x16GB DDR4-2133MHz Samsung ECC Server Memory
PSU: EVGA 1200W P2 80+ Platnium | Case: Phanteks Enthoo Primo | Cooler: 2x Noctua NH-U9DX i4 | SSD: Samsung 960 PRO 1TB | HDD: 4x WD Red 4TB
Monitor: 2x LG25UM56-P 2560x1080p @ 60Hz
https://linustechtips.com/topic/939264-1080p-advice/#findComment-11457136
