You totally should be able to, as it's the same chip, as far as I know anyways... The size shouldn't really matter, as long as you can connect them using the Crossfire bridge, although I'm not quite sure if you need one with those cards...
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
https://linustechtips.com/topic/939177-help/#findComment-11455823
What I forgot to ask: What motherboard and PSU do you have/What components are you going to build your pc with?
My gear:
#PCMasterrace
https://linustechtips.com/topic/939177-help/#findComment-11455828
