PLEASE HELP!
Go to solution Solved by BrinkGG,
How to fix the frame: https://www.tenforums.com/tutorials/27449-turn-off-show-window-contents-while-dragging-windows-10-a.html
How to change your default font: https://www.windowscentral.com/how-change-default-system-font-windows-10
 (NOTE: Google Chrome can use a different font from windows, so make sure it's the entire OS and not just chrome)
so i just switched on my pc and noticed the font changed. Not only that, when you move things that are open, it shows the frame of it before placing it. Is there a way to go back to the normal font and make it possible for the program open to move as you drag it? Please refer to the attachments
2018-06-19 16-01-51.mp4
https://linustechtips.com/topic/939176-please-help/
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/939176-please-help/#findComment-11455820
thanks a lot dude
https://linustechtips.com/topic/939176-please-help/#findComment-11455832
