Budget & Location
$1,000 USD, give or take $10. California, USA
2. Aim
Mainly video editing, some 3d work (eventually more), and gaming.
3. Monitors
Already purchased
4. Peripherals
Already purchased.
5. Why are you upgrading?
Switching from a Chromebook that was used only for web browsing.
Current build from PC Part Picker
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor
CPU Cooler: Cooler Master - Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte - B360 AORUS Gaming 3 WIFI ATX LGA1151 Motherboard
Memory: Team - Vulcan 32GB (2 x 16GB) DDR4-2400 Memory
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB OC Low Profile Video Card
Case: Corsair - SPEC-01 RED ATX Mid Tower Case
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply
Case Fan: be quiet! - Pure Wings 2 120 51.4 CFM  120mm Fan
Total: $1005.56 (as of June, 18, 2018)
Already have a 2tb HDD for adtl general storage. What I need most is guidance on the graphics card. I need at least 2 HDMI outputs, but as far as memory and gen, I'm as lost as you can get. My selected gpu was filtered from 4gb minimum and 4-5 star reviews, then sorted by lowest price up. Last question, regarding cooling, which path is better? What I have here, or water cooling? Not worried about maintenance, installation, etc, just what's most effective and better to use. If it goes beyondy price point, I would still appreciate the input for future reference. Thank you for all and any help in advanced!!!!
https://linustechtips.com/topic/938961-first-buuld/
32 minutes ago, Scruplez said:
Budget & Location
2. Aim
3. Monitors
Already purchased
4. Peripherals
Already purchased.
Also you can't overclock a 8600k without a z370 motherboard so unless you spend the extra money on that and a better cooler then there is no reason to get the 8600k.
https://linustechtips.com/topic/938961-first-buuld/#findComment-11453923
https://pcpartpicker.com/list/xCJ8ZR this is what I would get. Has a much better gpu and a cpu that is well suited for both gaming and productivity. If you are really dead set on going Intel I would suggest the i5 8400 as it is a way better value than the i5 8600k and should allow you to get a better gpu. Also 16gb should be fine to start out with and you can buy another 16 once you need it.
https://linustechtips.com/topic/938961-first-buuld/#findComment-11453946
Would a better gpu benefit the productivity or gaming aspect?
https://linustechtips.com/topic/938961-first-buuld/#findComment-11453994
20 minutes ago, Brooksie359 said:
The gaming aspect for sure but also productivity depending on the program.
All my editing will be through Adobe, not my first choice, but school is providing it so saving me a small fortune there, and then blender for 3d production.
https://linustechtips.com/topic/938961-first-buuld/#findComment-11454094
Then absolutely get the 2600x. The 2600x destroys the i5 in blender while in Adobe they preform fairly similar.
https://linustechtips.com/topic/938961-first-buuld/#findComment-11455549
since you already have 2tb storage i ditched out any storage in this list
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($174.69 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($55.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($449.99 @ Amazon)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ SuperBiiz)
Total: $999.63
Generated by PCPartPicker 2018-06-19 08:48 EDT-0400
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/938961-first-buuld/#findComment-11455600
