So I have the H700i case and I have my x52 kraken mounted up top a 140mm fan in the back pulling in air and three fans in the front as exahust but that is causing my gpu to get hot while gaming on some games what do you suggest for fans setup I have the stock fans that came with it but replaced them for the hue fans
https://linustechtips.com/topic/938878-help-on-case-cooling/
front: 3x intake
fans on the radiator as exhaust
fan in the back also as exhaust
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/938878-help-on-case-cooling/#findComment-11453232
2 hours ago, Faded_lmb said:
it sometimes peaks at 81 c
That's a bit high but still normal. If you swapped the top to exhaust and front to intake, temps would improve.
Make sure to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/938878-help-on-case-cooling/#findComment-11454788
