Need Upgrade Help
Solved by AndyLanderdahl,
Much appreciated, guys. After doing a quick look at the benchmarks I definitely think the 2600 or 2600x is defiantly the best way to go. RAM and CPU can definitely be upgraded latter, but RAM makes much more sense to upgrade later, given memory prices will be going down and it's expandable rather than replaceable. Admittedly, I hadn't looked at the 2nd Gen R5 and I'm much happier with the upgrade to 2nd Gen than I was with the 1st Gen R5s.
