Overclocking to 100hz with VGA input
Solved by Sauron,
There is no fixed maximum refresh rate for the cable itself, the limits come from the maximum bandwidth and what your gpu and screen support. The maximum throughput for a vga cable is 2048x1536 at 85Hz, so in theory you should have no issues with that (but that doesn't mean the screen can do it).
Featured Topics
halfbood_drag0n ·
2
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
