Corsair CS 750M eBay cable compatible?
Solved by Lehan,
It should work - but before you plug it in I suggest using a multimeter to measure voltages on each pin on each output. You can get one for under $10 and your readings on the motherboard connector end should be identical to the following:
http://nerdralph.blogspot.com/2016/03/hacking-gpu-pcie-power-connections.html
Featured Topics
nick name ·
Posted in General Discussion1 -
8
Cyber Akuma ·
9
ave11 ·
Posted in Troubleshooting1
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
