Hi,
i need a new PC since I'm working and gaming on a Laptop right now and it just isn't good enough anymore.
i would also like a PC for future upgradability.
I would like to pay about 1000€ so more or less 1000 USD since everything is more expensive here in the EU.
I can go some over budget but I don't think it should be necessary since my workload isn't that tough.
I am a casual gamer (Overwatch and open world RPGs mostly) on a 1080p monitor but i am also studying computer science so I need some CPU power for the compilation of my code and RAM for virtual machines.
I tried PCPartPicker and got that list: https://de.pcpartpicker.com/list/4F8gnH
I don't need an operating system since I can get that for cheep from my university.
Are the parts I pickled reasonable?
Thanks for your help in advance!
https://linustechtips.com/topic/937134-my-first-build/
Why the 2400G and a dedicated GPU? Why not the 1600 or something else?
Swapped some things around, Ryzen benefits heavily from dual-channel as well as fast RAM. If you can, try to add an extra 2x4GB kit down the road for the VMs
Changed the CPU and board out, dropped the cooler since the stock cooler with the 2600X is pretty good.
Dropped the PSU to something more sensible and cheaper but still very high quality (I was going to go for the 550 watt version but for $2 more I could get the 650 watt version)
Got rid of the blu-ray drive, get an external one for the times you do need it.
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  (€183.90 @ Amazon Deutschland)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  (€151.19 @ Mindfactory)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory  (€93.89 @ Alternate)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  (€109.99 @ ARLT)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€57.88 @ Amazon Deutschland)
Video Card: Palit - GeForce GTX 1060 6GB 6GB Dual Video Card  (€284.99 @ Alternate)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  (€50.98 @ Alternate)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (€82.99 @ Amazon Deutschland)
Total: €1015.81
Generated by PCPartPicker 2018-06-13 14:44 CEST+0200
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/937134-my-first-build/#findComment-11438054
PCPartPicker part list: https://de.pcpartpicker.com/list/zsK9Cb
Price breakdown by merchant: https://de.pcpartpicker.com/list/zsK9Cb/by_merchant/
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  (€234.95 @ Amazon Deutschland)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  (€79.90 @ Caseking)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  (€152.74 @ Amazon Deutschland)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (€62.00 @ Amazon Deutschland)
Case: Cooler Master - Force 500 ATX Mid Tower Case  (€39.90 @ Caseking)
Total: €995.35
Generated by PCPartPicker 2018-06-13 14:57 CEST+0200
Improved upon build. Twice the cores  and ram
https://linustechtips.com/topic/937134-my-first-build/#findComment-11438073
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (€168.89 @ Alternate)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  (€98.96 @ Amazon Deutschland)
Case: Thermaltake - Versa H26 Tempered Glass ATX Mid Tower Case  (€54.95 @ Amazon Deutschland)
Power Supply: Xilence - Performance X 550W 80+ Gold Certified Semi-Modular ATX Power Supply  (€63.99 @ Amazon Deutschland)
Total: €993.46
Generated by PCPartPicker 2018-06-13 15:02 CEST+0200
https://linustechtips.com/topic/937134-my-first-build/#findComment-11438087
If VM will be run, 16GB of memory would be the minimum I'd suggest.
Consider an Intel build. Higher performance cores which translates to slightly better performance in lightly threaded apps like compilers and most games.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  (€169.90 @ Caseking)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  (€89.47 @ Mindfactory)
Case: Fractal Design - Focus G Mini (Black) MicroATX Mini Tower Case  (€50.98 @ Alternate)
Total: €987.91
Generated by PCPartPicker 2018-06-13 17:25 CEST+0200
https://linustechtips.com/topic/937134-my-first-build/#findComment-11438534
I tried picking some parts for you
Motherboard: MSI - H310M PRO-VD Micro ATX LGA1151 Motherboard  (€60.59 @ Alza)
Memory: Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  (€143.10 @ Amazon Deutschland)
Storage: TCSunBow - X3 120GB 2.5" Solid State Drive  (€30.99 @ Amazon Deutschland)
Storage: Hitachi - Ultrastar 7K4000 3TB 3.5" 7200RPM Internal Hard Drive  (€57.16 @ Amazon Deutschland)
Video Card: KFA2 - GeForce GTX 1070 Ti 8GB EX Video Card  (€456.99 @ Amazon Deutschland)
Power Supply: SeaSonic - ECO 430W 80+ Bronze Certified ATX Power Supply  (€47.93 @ Amazon Deutschland)
Total: €1017.64
Generated by PCPartPicker 2018-06-13 22:15 CEST+0200
Notes:
CPU: i5-8400. ~15% Faster than the Ryzen 5 2400g
CPU Cooler: Stock cooler. Will be pretty noisy at times.
Motherboard: Basic Motherboard. No problem with this
RAM: 16GB Dual Channel. Okay RAM
SSD: 120gb Basic SSD. Good enough for Windows
HDD: Some noisy 3TB HDD. It will only be noisy sometimes, don't worry.
GPU: GTX 1070 Ti. YASSS!!! Some real gaming power
Case: The same one you chose
PSU: Cheap but okay quality
https://linustechtips.com/topic/937134-my-first-build/#findComment-11439376
  • 2 months later...
Total: €993.46
Thank you all again for your suggestions. I went with the quoted one above and it runs really well!
https://linustechtips.com/topic/937134-my-first-build/#findComment-11680288
