Hi All,
I have this case here (http://www.deepcool.com/product/case/2014-05/9_840.shtml). It says in the manual that the top should be intake. However, others say that it should exhuast. Im confused. I purchased some corsair SP120 and installed them as intakes on the top.
With stock fans included (not the corsair ones) with the case and 600-700rpm @ idle for both fans, the mobo is reading 49 degrees.
considering my stock ones are deepcool fans maxing out @ 1100rpm, and the corsair ones installed run @ 900-1000rpm with smart mode.
Questions:
1- Should i do 3 intakes (2 tops and 1 infront) + 1 exhaust (rear only) or a different combo?
2- what should i run the rpm at for the corsairs?
3- is 49 degrees high for system temperatures?
4- any suggestions or things i maybe missing? (proper settings for fans, etc)
https://linustechtips.com/topic/936687-case-fan-temperatures/
Case fans can be mounted either way and which way is best depends on your specs and how your airflow is configured.
https://linustechtips.com/topic/936687-case-fan-temperatures/#findComment-11433675
Im running a i5-8400, gtx 1060, m2 ssd.
Current airflow is 1 intake in the front and 1 exhaust in the back from factory.
https://linustechtips.com/topic/936687-case-fan-temperatures/#findComment-11433684
The stock case fans are fine as is. You can add an extra side panel intake for better GPU temps.
https://linustechtips.com/topic/936687-case-fan-temperatures/#findComment-11433724
