Any suggestions for a silent case with a window panel that has good sound dampening and decent airflow. I don't care about the fans as I can swap those out. Have the Silent base 800 in my sights but wondering if there is something more sleek looking that fits the bill. Unfortunately I'll be buying before the Silent base 801 arrives to the market :/
https://linustechtips.com/topic/935877-silent-case-with-window-panel-suggestions/
Imo well-built cases (so materials are thick and gaps match tightly) are already 90% as silent as the most quiet case (without going ridiculous on sound insulation materials). Using silent fans with enough airflow and overkill coolers for the CPU and graphics card helps reduce noise levels most.
Desktop benching:
My Define C from Fractal Design is quiet, looks great, and doesn't break the bank. I highly suggest it.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
23 minutes ago, Linturion said:
How does the Fractal Design Meshify C TG compare to the Fractal Design Define S Mid Tower with Window Black as far as sound dampening and airflow goes?
Meshify's cheese grater front leaks all noises out unmuffled.
For case to have any chances of muffling noise coming out from components there shouldn't be direct noise escape paths toward anywhere near user.
The Meshify C is designed for Airflow, plain and simple. It is NOT designed for silence.
The Define S, like many of Fractla's cases are designed for a balance of airflow and silence. The Define S is a bit older thoug and has been replaced by the Define R6. However, both these cases are larger (and more expensive in the case of the R6) than the Meshify C, so if you want a silent case thats relatively cheap and small, the Define C TG is your best bet. My Purple build in my signature uses a mATX version of that case, and it's very quiet! :)
