PC does not Post
Go to solution Solved by Shuaib Aliyu,
On 6/8/2018 at 9:51 PM, Brett_Bst said:
if you look here : Ram that module is not listed, don't mean it don't work but maybe that's why its not posting ? maybe speak to Asrock ?
On 6/8/2018 at 6:59 PM, LawlBot said:
wanna maybe send a photo of the board to see if we can spot anything wrong?
On 6/8/2018 at 6:57 PM, Jurrunio said:
Just in case, you're plugging the display cable into the graphics card rather than the motherboard right?
Also, dont forget the EPS connector on the top left of the motherboard.
Found out it was a DOA moatherboard. The tech said everything else works perfectly but the motherboard refuses to post no matter what is done. Thank you all for the help.
https://linustechtips.com/topic/935668-pc-does-not-post/page/2/#findComment-11433074
