PC does not Post
Go to solution Solved by Shuaib Aliyu,
On 6/8/2018 at 9:51 PM, Brett_Bst said:
if you look here : Ram that module is not listed, don't mean it don't work but maybe that's why its not posting ? maybe speak to Asrock ?
On 6/8/2018 at 6:59 PM, LawlBot said:
wanna maybe send a photo of the board to see if we can spot anything wrong?
On 6/8/2018 at 6:57 PM, Jurrunio said:
Just in case, you're plugging the display cable into the graphics card rather than the motherboard right?
Also, dont forget the EPS connector on the top left of the motherboard.
Found out it was a DOA moatherboard. The tech said everything else works perfectly but the motherboard refuses to post no matter what is done. Thank you all for the help.
https://pcpartpicker.com/list/7n7v4q parts
I just built this pc like 1 hour ago,and when i press the power button, everything turns on properly. After around 30 seconds,the pc will turn off and loop. There is no video output,no motherboard lights, no beeps or anything.Please help.
https://linustechtips.com/topic/935668-pc-does-not-post/
OMFG not a crap PSU in someone's new PC, again
Does it get into the BIOS?
Desktop benching:
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425227
Go through the standard not posting troubleshooting steps, reseat your ram, reinstall your GPU, ensure your cpu is in properly, make sure you didnt bend a cpu pin or something
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425229
2 minutes ago, Shuaib Aliyu said:
no,it lights up for around 30 seconds,then turns off....also crap psu?
so it doesnt get into the Asrock splash screen?
I mean, if you havent installed Windows then a PC would typically get through the splash screen, then either get stuck there or restart.
Desktop benching:
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425235
4 minutes ago, Shuaib Aliyu said:
also crap psu?
That's a tier 6 PSU in the list, while tier 3 is the minimum for units you should use for anything you care about
Desktop benching:
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425241
Nope,no display or anything. Just turns on,then turns off and restarts
Did that,,still no post
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425243
Desktop benching:
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425259
3 minutes ago, Shuaib Aliyu said:
was a bit tight on budget at the time,didnt plan on keeping the psu for tooo long
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425266
tried all that of that...still nothing
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425341
8 minutes ago, Shuaib Aliyu said:
nope
so did you do it step by step from the manual or just do it as you go ?
I assume all parts are new ?
you have made sure the ram is compatiable with you cpu/motherboard ?
you have tried with the one ram stick in all the slots ?
you have tried re seating the graphics card ?
Made sure all connections are pushed in propley ?
Clear the CMOS ?
Take off the case connection pins for the start button etc and try running it with no of them connected and start it by bridging the 2 power pins ?
I will get bk to you with more :D
I7 7700K @5.0ghz, Asus Z270-P, Corsair H115i, hyperX 16gb, Asus duel 1070, Nzxt H440
https://uk.pcpartpicker.com/list/ZTsYD8
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425393
Clear the CMOS ?
tried all of that and nothing worked
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425397
2 minutes ago, Brett_Bst said:
so you say no lights on the motherboard come on ? do the lights on the rx480 come on ? do fans spin ?
i dont think the motherboard has light,and yes everything else turns on normally
Edited by Shuaib Aliyu
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425404
well its hard to say without the pc but I would guess its a ram issue and without new ram to test its hard to test things like the cpu and gpu or power supply,  mayne there is an issue with the motherboard ?
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425441
the ram listed on pc part picker is that the one you brought ?
can u list the module part numbers it will be like : AX4U2400W8G16-DRZ or some think like that
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425450
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425523
I just went ahead and gave up,if the ram is the problem ill know tommorrow when i take it to microcenter. Also if it IS the problem im going to be pissed because this ram was delivered a week late and it was the last part i was waiting on.
https://linustechtips.com/topic/935668-pc-does-not-post/#findComment-11425531
