hey i recently got an hp envy x360 with i7 8th gen and a nvidia mx150
the problem am facing is sudden frame. every few se onds drops while plugged into ac adapter
but it runs smooth on battery
my ac adapter is a 90w not 65w
ive tried tweaking nvidia panel settings to maximun performence
updating bios
set power plan to high and adjusted everything in advanced power settings  to favor pluged in
tried to undervolt the gpu
Uninstalling gpu drivers and install the latest ones
nothing worked...
when i investigated it
in task manager :
when plugged in gpu is at 100 load and  fps drops suddenly every few seconds
when unplugged gpu is at 40-50% load with absolutely no frame drops
the only weird solution that has worked
is that i have created a new power plan and set it to battery saver
 now while plugged in there r no fps drops but in task manager the gpu % is from 40 - 50 % ( same effect while unolugged when i had the problem)
my question is
using this fix will i always be capped at 40-50% gpu?
are there any other fixes
https://linustechtips.com/topic/935456-nvidia-mx150-problem/
using external monitor? . windows 10 updated? drivers updated? If its new well that doesnt have to happen
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/935456-nvidia-mx150-problem/#findComment-11423141
You'll need to do some more logging here. Run MSI afterburner's overlay with GPU usage, CPU usage, clock speeds and temps to see what exactly happens when the framedrops occur. It'll narrow down where the problem lies.
Also, the 8th gen CPUs tend to throttle quite hard when they get hot, and often the CPU and GPU share the same heatsink assembly, especially with entry level dGPUs like the MX150, so when the GPU heats up it might aggravate the CPU throttling which causes the framedrops.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/935456-nvidia-mx150-problem/#findComment-11423230
