Hi I'm 14 and would like to buy my first proper gaming desktop , I have saved up around 1400 USD and I would like to get the new Hades Canyon NUC as it has crazy IO and perfomance that puts my ps 4 to shame , I'd like to ask a few questions first though
1.What sort of ram will I need (I know I need 16 gb of soddimm memory but not sure about the amount of mhz and condiguration)
2.What sort of an ssd will I need (I thought about 500 gb 970 evo since its quite fast )
3.How can I protect my previous PC from ESD discharges during assembly?
4.Since the skull looks sick , could I mount it on my wall with the VESA adapter?
https://linustechtips.com/topic/934501-my-first-pc/
Do you need small form factor like that, or can you build one? WIth 1400USD you'll have wayyy better performance than the Hades Canyon NUC
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413543
2 minutes ago, hconverse02 said:
With $1400 at your disposal, I'd recommend getting a much higher spec'd full desktop.  Do you need a monitor, keyboard, mouse and windows key?
I can't really get a full desktop and even if so I'd rather have a NUC beacause I can't really take a desktop to my grandparents (I go there quite often).
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413550
You could as long as you can bring a keyboard/mouse and they have a monitor there
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413552
is this the nuc you're planning to get?
https://www.intel.com/content/www/us/en/products/boards-kits/nuc/kits/nuc8i7hvk.html
i7-7700k @4.8GHz
Asus Maxmius IX hero
EVGA GTX 1080Ti FTW 3
850w EVGA PSU
32GB corsair LPX ddr4 ram
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413561
Not sure to be honest , most of the time I'll use my NUC for gaming hence I'll just use a wireless controller when I'll visit them and we'll the nuc is just 2 pounds + the power brick vs 30-40 pounds of a full desktop . And the perfomance levels of it satisfy me.
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413567
Lol a desktop weighs like 15lbs
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413573
1 minute ago, hconverse02 said:
https://unlocked.newegg.com/article/intel-hades-canyon-nuc-benchmarks Fuck, however the most expensive unit is way out of your budget.
I don't think so , I already have a Windows license and a 500 gb 970 evo is 200 USD + 999 for the nuc + 160 for the ram I think.
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413576
1 minute ago, PySlims said:
Yes the 8809G version of it with vega m gh.
Ok! the NUC does not support 2.5" dirves so you will need a M.2 SSD with the max size being 2280. As for the RAM you will need a SO-DIMM ram DIMS. The Nuc supports up to 32GB @2400MHZ. You can use the nuc but why not a decent laptop?
i7-7700k @4.8GHz
850w EVGA PSU
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413585
https://www.amazon.com/Intel-Machine-NUC8i7HVK-Radeon-Graphics/dp/B07BR5GK1V?th=1 Is this the one? Similarly priced? Get this for the ssd and ram: https://pcpartpicker.com/product/GjZ2FT/corsair-memory-cmsx16gx4m2a2400c16 https://pcpartpicker.com/product/P4ZFf7/samsung-970-evo-500gb-m2-2280-solid-state-drive-mz-v7e500bw
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413591
Why don't you get a gaming laptop? Easier to carry + comes with a screen bla bla. $1400 will def get you a nice system.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
https://linustechtips.com/topic/934501-my-first-pc/#findComment-11413607
