Alright so I’m and completely new to forms and things like this. So bare with me if I’m a noob but anyways I have a program that’s called rainmeter and it basically makes Windows look better, and on rainmeter you can get skins and the skin I’m having trouble with is the honeycomb skin and the “folder” shortcut, honeycomb or what ever you call it. When I was trying to find and add in the right file location so when I click on the shortcut it opens the file explorer I accidentally deleted the entire code.... pls can some one give me a link so I can copy and past it back in or tell me what to type and then tell me how to link the file explorer up to the shortcut so it will work when I click. Thanks maybe I can show pictures later.
https://linustechtips.com/topic/934370-help-rainmeter/
Go download the skin again and just copy the code from the fresh one.
https://linustechtips.com/topic/934370-help-rainmeter/#findComment-11412091
4 minutes ago, Budddy27 said:
It’s not the skin it’s the code (for lack of better words).
The code is literally what the skin is......................................
When you download a rainmeter skin it has image and code files for every feature or tile.
https://linustechtips.com/topic/934370-help-rainmeter/#findComment-11412111
Ok I got the code back could you help me with the code so it will always open the file explorer. I have clicked on properties like you usually do but I can’t copy the link. And when I went to the rainmeter web page they had stuff about the link to folder and other windows programs. I just don’t understand it. Sorry for my ignorance.
https://linustechtips.com/topic/934370-help-rainmeter/#findComment-11413611
https://docs.rainmeter.net/tips/launching-windows-special-folders/
You just need to figure out where you want file explorer to open to.
https://linustechtips.com/topic/934370-help-rainmeter/#findComment-11414749
