I am Working on a new build for my daily gaming rig... I want it to be watercooled so I can overclock the crap out of the Ryzen 7 2700X and the GTX 1080. I just want to know if the Parts I have in my list are compatible or if I am missing something... Basically I just want to buy all the parts I need and then just build it like a lego set
Here is the list
Component Type
Model
Price
CPU
Ryzen 7 2700X
$319.99
Thermal Paste
Arctic Silver - 5 High Density Polysynthetic Silver
$5.95
Motherboard
Asus Rog Crosshair VII Hero
$299.99
MonoBlock
EK-FB Asus C6H RGB Monoblock
$182.99
Ram
G Skill Trident Z RGB 4x8GB 32GB Ram
$413.99
Storage
Samsung - 1TB PM961 M.2 SSD
$449.99
Graphics Card
Asus - GeForce GTX 1080 Strix
$629.99
GPU Waterblock
Glacier G1080 Asus Strix
$156.75
Case
ThermalTake View 31 TG RGB
$121.99
Reservoir/Pump Combo
EK-XREZ 140 Revo D5 RGB
$215.59
Radiator
EK-CoolStream SE 360
$91.49
Fans RAD/CASE
3x Thermaltake Riing 12 RGB 3-pack
One: $57.00
Three: $171.00
Power Supply
Thermaltake - 1000W 80+ Gold Certified Semi Modular Power Supply
$169.59
Cooling Liquid
EK-CryoFuel Acid Green
$9.99
Tubing
EK-DuraClear 9,5/15,9mm
$17.99
Fittings
EK-ACF Fittings 10/16mm
$7.99
N/A
EK-Cable Y-Splitter 3-Fan PWM
$3.99
N/A
EK-ATX Bridging Plug
$2.49
Thanks Please Tell Me what I need to add to the List
https://linustechtips.com/topic/934152-will-this-build-work/
Get a 1080ti because your budget is so large. You can take some of the price from the ram and the motherboard if you don't have another $150 sitting around.
 https://pcpartpicker.com/product/Yr8H99/asus-geforce-gtx-1080-ti-11gb-video-card-strix-gtx1080ti-11g-gaming
https://linustechtips.com/topic/934152-will-this-build-work/#findComment-11409970
Talk about over-priced build.. given how the 1080 is in an odd place right now where the cheaper 1070 Ti is pretty much just as good you might want to consider the 1080 Ti already... specially on how you're spending a shit load of money on every thing else already.
Get a better PSU as well... like a Corsair RM850x if you totally want over-kill wattage at least this one is of better quality and more silent.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/934152-will-this-build-work/#findComment-11409978
jesus christ this is so unnecessary, if you're an enthusiast and you want the best stuff only, i understand that (even though it doesn't make anything better, its only for looks and bragging), but you're picking the GTX 1080 and wasting the rest of your money on waterblocks?.......
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/934152-will-this-build-work/#findComment-11410073
Custom loop questions are better asked in Liquid and Exotic Cooling.
The Samsung 970 Evo is newer and less expensive tech.
1000W is far more capacity than could be used. Allowing for overclocking, a 750W - 850W psu is more than enough. I'd also suggest a fully modular Seasonic Focus Plus, Prime, or Corsair RMx model.
It's not like putting lego together. There is some careful work needed to remove the gpu air cooler and install the water block. One also needs to be extremely careful and patient assembling and testing the cooling loop.
I join the others in suggesting a GTX 1080 Ti. EKWB has Aura Sync compatible water blocks, https://www.ekwb.com/shop/ek-fc1080-gtx-ti-strix-rgb-nickel.
https://linustechtips.com/topic/934152-will-this-build-work/#findComment-11410168
