Hey. I'm planning to build a pc in a very small case. The max supported length of a Graphics card is 170 mm (17 cm). I've found the Gigabyte 1070 mini OC edition, but i want to look at other options. I'm looking for something like a 1060, 1070 or maybe 1080. Thanks in advance.
https://linustechtips.com/topic/934065-small-gpus/
The GT710 is quite small, but it's not much of a gaming card.
Have you considered something from the AMD/ATI lineup?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/934065-small-gpus/#findComment-11409239
I think that the smallest 1080 is the Zotac Mini which is 210mm. I do not think you can fit a 1080 in there.
What is your budget? What do you want to do with the PC?
A range between 1060 and 1080 is quite big...
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/934065-small-gpus/#findComment-11409256
There's this thing, Gigabyte gtx 1080 mITX. Cooling is a problem though, and this thing either runs fairly warm (nearly 80C) or shouts loud.
@CyrricaneDoes your case have height limits as well? The Gigabyte mITX cards are quite tall.
Desktop benching:
https://linustechtips.com/topic/934065-small-gpus/#findComment-11409263
Alright. Props to people at Gigabyte for being crazy enough to create a 169mm 1080 lol (and sorry for providing a wrong answer).
Unraid Server
https://linustechtips.com/topic/934065-small-gpus/#findComment-11409291
