h115i issues, go custom?
Go to solution Solved by mrmonmon2,
FOR FUCKS SAKE, I THINK IT WAS A BUBBLE
67 C UNDER XTU STRESS TEST, WATER TEMPS NOT CLIMBING LIKE A ROCKETMGVJLE AGSHBU EZRHI BIJHZE RJOGBV EW
water temps actually taking time to go above 30c
yup ffs rad mounted now so highest point is not the tube end(was issue with  tube length and mountable spot)
99% sure its failing, Rad is cold, water temps at 44c rn and only one hose is hot to the touch, RIP me
Can anyone recommend the best bang for my buck to do a custom loop, I also wonder would it be viable to splurge on a good ek block and pump and use 5-10 gallons of water as a secondary reservoir with fans instead of a rad(till I can reasonably afford a good rad?)
IDLE on start water temp 23 c, cpu at 40-50c
gain about 0.1c every few seconds untill about 35-40c water temp
Gaming water temps at 40 minimum, cpu at 70-85c
rad cold in both cases
under load/gaming on tube is burning hot
I have a hybrid gpu atm so looking only for cpu loop, next gpu will be a hydro copper in probably a few years
considering going with pump and water block and a bucket of water with aquarium pump as suggested to make a fountain temporarily rather than a full setup right off the bat
bought this second hand for 80$ but asking corsair what I can do, inb4 nothing
https://linustechtips.com/topic/933966-h115i-issues-go-custom/
Check your pump to see if it's running and ensure that it's being provided the full 12V. As for custom loop if you want a proper copper based look your looking at around $500 USD for both a CPU and GPU, EKWB does have their fluid gaming lineup which is a bit more affordable at around $350USD.
Most loops will only use around 2L of fluid, I would suggest looking at the kits if your just starting out.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408130
A few comments
First a custom loop is always a bad investment for bang for the buck, you will always find performance improvements elsewhere.  It's mainly for appearance and silence with the ability to cool a gpu as well.
Second A large reservoir will eventually heat soak, many years ago I experienced this by trying to put a res in a mini-fridge instead of using a radiator, the fridge couldn't keep up and quickly got heat soak and turned into a sauna.  I did a couple other things as well as I didn't have a radiator, one of those being a storage tote full of water with a popcan rigged in the middle with holes in it to use evaporation to cool, this worked rather well but was jenky AF.  I also did a large 4"ish pvc tube with water spraying in the top and air blowing through it, kind of a bong setup.  Honestly I can't remember if I ever got the PVC setup fully functional.
Third if you still want an affordable custom loop I would look into EK's aluminum kit, there is nothing wrong with it so long as you don't mix pieces from outside the kit as you'll get galvanic corrosion.
I would seriously look at another AIO, I've done a handful of custom loops and my next machine is either going to be from Singularity Computers or AIO, nothing inbetween.
edit: if going forward with a custom loop........ the hardest lesson I learned is that the majority of gpu's are non-reference boards meaning they are proprietary lay outs.  Some of the main non-reference like strix have custom blocks made for them but unless a gpu has a specific block for it or is reference you simply can not cool it in your loop.  I have 3 gpu blocks that are worth no more than the copper they're made out of from learning this fact.
Audio go Brrrrrr
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408131
Don't cheap out on a custom loop, unless you enjoy killing PC components and buying a whole new PC.
First of all, find out what your CPU temps are because 44C water temps and one hose warmer than the other is normal.
Second, replace the thermal paste and try mounting the cooler again if the CPU is still overheating.
Third check that the pump is running, making sound and showing the right rpm.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408133
Pump is making noise, 1080 TI hybrid so CPU Only
10 minutes ago, Psittac said:
A few comments
Silence is essential and why Id like to go custom, As for the large reservoir setup it'd be like 1-2 months temporary at most.
Ek isnt exactly the best option for price As i'm Canadian
gpu wont be custom till I buy my next one, and will probably go with an evga hydrocopper
23c water temps and 50c idle when start, like one hose is burning and the other is cold.
70-85 playing pubg
Replaced thermal past several times and yes pump is making noise and running
I intend to not cheap out but buy cheaper (BUT STILL GOOD) components or go with a large reservoir temporarily before getting a rad
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408165
70-85 playing pubg
If you want to step up to custom watercooling this is what I would recommend to start with the P series kits are an excellent base to start a loop on and will have enough cooling capability for an EVGA hydrocoper GPU.
https://www.ekwb.com/shop/ek-kit-p360
If you plan to get a reference 1080ti or one compatible with the Fluid gaming kits that can save you a marginal amount but any custom loop is going to be a fair bit of money. You cannot use the fluid gaming kits with any copper based parts, they must all be aluminium.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408177
well if you are stuck on this path, I'd suggest getting a small aquarium pump and making a sort of water fountain to increase cooling potential.  The evaporation will dump heat you just need to top it off.  Also when I did the pop can thing, I had a very large and very powerful external aquarium pump, Think something in this category.  So I'm not sure what a d5 or ddc would do with an external large reservoir.  You need to research the effects of head pressure
Audio go Brrrrrr
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408178
70-85 playing pubg
If your water temp is actually 23C then the hose would not be "burning"
RMA your cooler to corsair or figure our what exactly is wrong with it.
If you want to go with custom watercooling then you should have at least $500 to start.
Otherwise just buy another AIO or air cooler.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408179
Have 1080ti already but thank you for the suggestion
hmmm not yet but thoroughly considering, I do have aquarium parts at home so probably have a spare pump, imo Id just be hoping the pump could handle sucking from the bottom of a bucket and duping back into it on the top, I do have plenty of spare fans so i could actively cool said bucket for the time being
cpu only custom, also updated OP post to include your questions my head is a tad over the place, but Ive actually been running like this for 2-3 months but I thought it was a OC issue causing the occasional BSOD
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408220
$500 is for a CPU only loop. Adding a GPU would be at least $100 more.
An overheating CPU would not cause a BSOD so clearly you have other issues with your system.
If a CPU gets hot it will throttle itself to a lower frequency.
If it still gets too hot the PC will shut off immediately with no BSOD.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408231
Bsods during pubg and pretty sure that's partially a reason for those
But it's still too hot
And I'm sure it can be done cheaper and jankier
Edited by mrmonmon2
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408238
About the 115, check:
thermal paste
backplate, if it's loose, tighten it using rubber washers between the mobo and the plate
if you still have problems, remove the copper plate from the block by removing the 8 screws, do it holding the plate facing up to prevent a leak, once opened use a cotton swab to remove any grease, dust or weird thing you see (my 110 had some weird mucus like thing inside, I don't know what it was) once you do that put the copper plate back and tighten the screws, you could also lap the plate to improve contact
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408247
It shouldn't be too hot unless you mounted it incorrectly or it is defective.
If you want to risk killing your PC and potentially losing all your data too then that's up to you, go ahead and cheap out on your loop.
In the long run you will waste more money replacing dead PC parts than having bought a good quality loop in the first place.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408249
thermal paste
Thanks I'll try that tomorrow morning!
Thank you for your advice, but as I've stated my intention is not to buy low quality parts but to possibly avoid expensive parts such as ek blocks if I were to go the full loop at once
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408289
Uh, the "not buying low quality" part means buying an EK CPU block, bitspower fittings, and other parts which are not cheap.
If you want to avoid the good reliable parts then that means you're cheaping out and should not be making a custom loop.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408301
I'm willing to buy ek but I'm wondering if there are any other hQ alternatives as being Canadian prices are insane and considering the possibility of paying duty aswell
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408305
That's why I said $500  minimum, that's 300-400 USD.
You also need to buy fittings, tubing, fluid, and all those small things add up.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408318
15 minutes ago, mrmonmon2 said:
Yes I am aware, but are there no other high quality alternative to EK?
None which have been sold anywhere near as much to know their reliability.
Companies like bitspower or alphacool also make good stuff but they sell far less CPU blocks so you can't really judge the reliability by the low numbers.
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408808
Alright thank you for that, I'll research others more if i chose that route, for now a friend suggested i  reorient it as it may be a bubble
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408927
https://linustechtips.com/topic/933966-h115i-issues-go-custom/#findComment-11408944
