How to cool Ghost S1?
3 members have voted
  1. 1. How to cool Ghost S1?
    • A. Top hat - None, Case fan - None, CPU - Air cool, GPU - Air cool
    • B. Top hat - Small/Medium, Case fan - Slim/Regular size, CPU - Air cool, GPU - Air cool
      1
    • C. Top hat - Large, Case fan - None, CPU - Water cool w/ 240mm rads, GPU - Air cool
    • D. Top hat - Large, Case fan - None, CPU - Air cool, GPU - Water cool w/ 240mm
    • E. Top hat - Large, Case fan - None, CPU - Water cool w/ 120mm, GPU - Water cool w/ 120mm
      1
    • F. Other suggestions (ex. from using more than 1 top hat)
      1
mates,
I'm one of the backers for ghost s1, from Korea (south i must say)
unfortunately, we don't have enough information about ghost s1, so here I ask.
(I'm a real noob)
+Considering factors
So I'm planning for 2700x + asus strix x470 + 1180 (waiting).
I'm planning to OC my ram, but not for my cpu/gpu.
I'll be using only this PC for PUBG + streaming (just a hobby)
I am considering top hats, but I would like to keep my case as small as possible.
+The real problem
Cooling is becoming a real headache and I was hoping for suggestions on following possible options.
GPU - Air cool
+ Questions
1. Which option would you suggest? Any other suggestions?
2. Can 1 large top hat create enough space for two 120mm rads instead of 240mm rad? (noted above option E)
3. On ghost s1, would you suggest a blower type, or non-blower type gpu?
Because I heard that usually for itx cases, blower types are the way to go?
Please let me know!
Thank you!
Cheers, K
* Here is a diagram that may be helpful. More information on http://louqe.com
https://linustechtips.com/topic/933780-itx-cooling-conundrum/
Interesting case, on the gpu front you should be fine with either type.
For the case decision I would choose small or medium top, Noctua makes a few nice (under 66mm) coolers that will fit & cool excellent in that case.
Also for the sfx psu you will require... Corsair has the 2 best options, SF450 & SF600
I have a cue light I can use to show you when I’m joking, if you like.
https://linustechtips.com/topic/933780-itx-cooling-conundrum/#findComment-11408605
I have an Ncase M1 with that same setup. I have 4 120mm Noctua NF-F12 case fans all on intake and am using a Bequiet Dark Rock TF which fits perfectly. The thing is nice and cool.  Idles at 40c, gaming in the low 60s, synthetic stress tests push it to low 70s.
https://linustechtips.com/topic/933780-itx-cooling-conundrum/#findComment-11408766
@TARS @geo3
I'm guessing you guys are not particularly suggesting the water-cooling option?
THen would you suggest I choose to go with
1. small top-hat with slim case fans on top exhaust?
2. medium top-hat with regular fans on top for exhaust?
3. small top-hat with slim case fan on top for exhaust + medium top-hat on bottom with regular fans for intake?
* Here is the configuration testings that might help.
http://louqe.com/img/GhostToHatTest.pdf
Any suggestion/idea would be really helpful.
https://linustechtips.com/topic/933780-itx-cooling-conundrum/#findComment-11410788
