Sudden Microphone Failure?
Solved by JanFrode,
I assume you are using Windows 10.
Did your Windows just update to the Spring Update?
If so, you might have to go into Settings -> Privacy -> Microphone and toggle on the "Give apps access to the microphone" or something.. Mine is in Norwegian, so I'm not 100% sure what it says in English
Featured Topics
atxcyclist ·
Posted in Home Theater Equipment0 -
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
