Heyo LTT.
I'm hoping I can get some advice for manual overclocking. In the past I've always used the motherboard presets trusting it would be pretty solid.
However I would like to try manual overclocking to see if I can get more out of my system, if that's possible?
Right now my PC doesn't have any OC setting applied, so everything is running at stock speeds.
I'll post my parts list below, hoping you guys would be able to help me out.
MOBO: ASUS ROG Strix X99 Gaming (bios is up-to-date)
CPU: Intel Core-i7 6800k
SINK: Corsair Hydro H80i
RAM: Corsair Dominator CMD32GX4M4A2400C14
GPU: ASUS ROG Strix GTX 1080
DRIVE: Samsung 960 Evo 250GB
(Plus other storage pieces and a capture card, if that makes a difference)
https://linustechtips.com/topic/933319-manual-overclocking-assistance/
1. Start with something reasonable (e.g. 3.7 ghz 1.2v or something)
2. Stress test with something like Asus Realbench to ensure stability for 5 minutes
3. If it passes, bump the core clock by 100 mhz
4. Stress test for 5 minutes
5. If it passes, go back to step 3, otherwise go on
6. If it fails the test but temps are reasonable (Below 80C is a good target) and voltage is below 1.35v bump the voltage up by 0.01v then go back to step 4.
Once you hit the temp and/or voltage limit stress test for at least an hour to make sure the OC is stable. I've had OCs that pass a 5 minute stress test fail a 15 minute one.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Awesome, thanks for the Step chart. I'll go through this when I have the time.
I personally leapfrog this stuff, as in - check the typical oc values of most chips and start from there, but what @DocSwag said is the correct and safe approach albeit a bit tedious.
To the final stress testing I'd add running Cinebench few times in a row as well because I had it happen to me when my CPU was supposedly stable only to fail at like 7th Cinebench run.
CPU: i7 6950X  |  Motherboard: Asus Rampage V ed. 10  |  RAM: 32 GB Corsair Dominator Platinum Special Edition 3200 MHz (CL14)  |  GPUs: 2x Asus GTX 1080ti SLI
Storage: Samsung 960 EVO 1 TB M.2 NVME  |  PSU: In Win SIV 1065W
Cooling: Custom LC 2 x 360mm EK Radiators | EK D5 Pump | EK 250 Reservoir | EK RVE10 Monoblock | EK GPU Blocks & Backplates | Alphacool Fittings & Connectors | Alphacool Glass Tubing
Case: In Win Tou 2.0  |  Display: Alienware AW3418DW  |  Sound: Woo Audio WA8 Eclipse + Focal Utopia Headphones
