Intel® Core™ i7-7700 4x 3.60GHz
Cooler Master Hyper 103
8192MB DDR4 Kingston ValueRAM 2400MHz (1x8GB)
4096MB NVIDIA® GeForce® GTX™ 1050 Ti
Gigabyte GA-B250M-D2V (Chipsatz:B250/mATX)
250GB SATA III Samsung 850 EVO SSD
1TB SATA III 7200upm
DVD-RW / DLayer \"black\" bulk
550 Watt Corsair Vengeance 550M 80+ Bronze
WLAN Karte 867MBit PCIe ASUS PCE-AC55BT B1
i had gtx 1050 ti and it worked good,but i wanted to ubgrade to gtx 1080 but now my mouse and keyboard dont work and my monitor cant detect display port please help,is it because i need better pcu?
https://linustechtips.com/topic/933282-gpu-problem/
Something is very wrong with Windows here. Find a way to boot into safe mode, if at all possible. I'm suspecting drivers.
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/933282-gpu-problem/#findComment-11402116
Does your PC still work when you install the 1050Ti instead of the 1080? Do all your fans and lights work? Does the PC post?
-Moved to Troubleshooting-
https://linustechtips.com/topic/933282-gpu-problem/#findComment-11402119
Did you plug the right power cables into the GPU? When swapping GPUs for testing etc, I've noticed windows will start via a "readying devices" menu (or something similar, not an english W10 install). If I don't plug a monitor cable into the gpu BEFORE starting the machine after swapping GPUs, it won't display at all. When I turn it off, plug the cable in and turn on again, it's always worked though.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/933282-gpu-problem/#findComment-11402128
