motherboard About Motherboard Fan Headers
Solved by Jurrunio,
They will appear in different names inside the BIOS (say an intake fan plugged in AIO pump header, it will show up under AIO pump in the BIOS), and some might not have a controlable fan curve in there at all and will run at full speed.
16 minutes ago, Leinad4400 said:Those fan headers would be wired to different thermistors, and thus wouldn't react to ambient temperatures the way case fans are meant to
For much older stuff and OEM motherboards that is. Reasonably modern motherboards do not have thermistors directly wired to the controller of headers, but all route to the controller without hardcoded logic and rely on software control.
