Total Water Cooling newbie
Solved by AverageAfro,
OK. So I might not be going to water cooling. I looked in my PC and it turns out I'm running 2 crappy random 140mm fans in the front... I was under the impression I was running all noctuas. My fan curve was also shit because I had 2 programs that were setting the speeds and the one with a bad fan curve had control. So I ditched it and the temps dropped a couple degrees an the sound became good again.
I don't know what happened... Anyway. I'll be buying a couple of Noctua 140mm, Might go industrial so that I can get some more air flow through those smaller side vents. Will research this more.
Thank you for your help though guys! Turns out I'm just an idiot!
