After building my first pc, I installed windows 10 but the resolution was zoomed in so much I could not see the menu. The option to change the scale and resolution was also greyed out. I then installed ubuntu to see if it was the same and it was (though I could change the resolution, there was no resolution that fit properly). I have not yet gotten my gpu so I am running the iGPU on my processor. I have also installed all additional drivers for the mobo.
Specs: Gigabyte b360m DS3H; Pentium G5500; 500w PSU;
Thanks for all the replies in advance!
https://linustechtips.com/topic/932226-resolution-problems-after-building-a-pc-igpu/
if its plugged into a TV, its a tv setting, like "cinema zoom" or some crap like that
Main PC:| CPU: Ryzen 5 2600 @ 4.1, MOBO: Asus B350 PRIME , RAM: LPX Vengance 2400 16gb kit, GPU: 980Ti Poseidon Platinum 6gb
                PSU: SilverStone Strider Gold Evolution 1200w , CASE: HAF 932  HDDs:240gb EX900 HP NVME 6TB (2x3 Seagate Barracuda)
                COOLING: ThermalTake Contac Silent 12
Laptop:MSI GL62 7RD  CPU: Core i5 7300HQ, RAM: 16GB 2400mhz, :GPU GTX 1050 2GB: HDDs: 256gb adata NVME + 1TB HDD
love all brands, will go for whats cheaper for my needs
