my system: cpu: AMD Athlon II 2x 250 2cores 3Ghz (overclocked to 3.3)
                   gpu: GeForce GT 710 1gb
                   1TB sata Harddrive
                   Motherboard: ASUS M2N68-AM SE2
                   Ram: 2 Samsung 4gb sticks ( dual channel)
I was thinking of playing modern games like battlefield 4 and gta 5 and like cod black ops 3 but that is just not possible with 2Cores ( at least thats what i think)
i was getting like crazy Studder and i was thinking its probobly the cpu with its all and MIGHT 2 CORES, SO.
i was thinking of upgrading it to Phenom 2 x4 945 which has the same freq at 3ghz (planning to overclock) but it has 4 cores would it help in this situation
PS: ik my rig bad but i feel like a good processor is all it needs for my satisfaction
( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/932004-i-need-help-with-cores/
The CPU upgrade will definitely help, but you still have a gt 710 and i would recommend trying for a used 750ti or even a gt 1030 alongside the new phenom x4.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/932004-i-need-help-with-cores/#findComment-11390266
1 minute ago, TranquilElder said:
Thank you for your response i will keep it in mind
No problem.
I would think a 750ti would cost somewhere around 50USD on the used market.
https://linustechtips.com/topic/932004-i-need-help-with-cores/#findComment-11390278
2 minutes ago, TranquilElder said:
Its about 100$
3 minutes ago, GoldenLag said:
What is your budget for this upgrade?
Location?
https://linustechtips.com/topic/932004-i-need-help-with-cores/#findComment-11390285
