I recently upgraded to i5 8600k on Asus z370 prime and gtx 1070 founder edition, now i need to upgrade my Psu from 450w evga to 650w or 750w Psu, any recommendation?
Also i would like to overclocking both Cpu and Gpu, maybe add another gtx 1070 for sli
Thank you all for any help
https://linustechtips.com/topic/930696-power-supply-upgrade/
450 watt is still enough for what you're running, even when slightly overclocked, if you plan on heavy OC'ing go for 550. and SLI is a waste of money as fewer and fewer games have support for it.
What's the model of your PSU though?
https://linustechtips.com/topic/930696-power-supply-upgrade/#findComment-11378545
For one, 450W would be plenty for your system, but I assume you have a 450B which isn't a great unit.
Second, don't bother SLIing two 1070s. SLI in general is a dumb idea and to do it with two cards that aren't the top-end is just wasting money when you'd get better performance by selling your old 1070 and getting a 1080 Ti.
A Seasonic 550W Focus Plus Gold can often be found for pretty cheap and will do fine for your particular system with any dGPU and limitless OC.
https://linustechtips.com/topic/930696-power-supply-upgrade/#findComment-11378581
13 minutes ago, Moonlight warlock said:
Is the rating for psu will matter or should i go with bronze rating is fine for the overclocking?
Sorry i am new to these
Appreciate all your help
The 80+ rating is for efficiency, nothing else. So you can have a crappy bronze rated PSU, a crappy gold rated PSU, a good bronze rated PSU or a good gold rated PSU etc. You have to check the unit in question.
https://linustechtips.com/topic/930696-power-supply-upgrade/#findComment-11378972
