So i'm building my first ever PC and i want it for gaming. I would like to stick the Intel proc and i'd like to know what would be the best one for the job. I keep reading online that the i5 is the one or the i7 and now my head is spinning. can someone please help me.
https://linustechtips.com/topic/930318-my-first-build/
Let's start off simple. What is your budget (and currency)? What kinds of games are you looking to play? Are you willing to lower settings or do you want max settings on everything? Also, what computer parts do you already have that you could carry over to your new build (monitor, keyboard, mouse, etc.)?
https://linustechtips.com/topic/930318-my-first-build/#findComment-11373984
i5's are great because they're still pretty good, and they're a bit less expensive than i7's. i7's  are newer, some have more cores and are just better but also more expensive.
(what I gathered from like 2 articles I read)
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/930318-my-first-build/#findComment-11373994
the only things i've picked up so far are a mouse, keyboard. so it really is my first build. i've got max 1300 to play with but that doesn't mean i have to spend all of it if i can help it. I would like to be able to play ESO (Elder scrolls online) Overwatch and ark. at 60fps if that is possible. if i figure out what proc to go with i might be able to figure out the rest. theres just so many
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374000
Just now, Lenovo1984 said:
You realize that there are i3s, i5s and i7s that are all current generation, right?
I just skimmed a few articles and went with that little bit of information to make a kind of informed answer.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374003
are you just gaming or also streaming/editing/rendering? which country are you in? need monitor/OS?
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374010
Sorry buddy i meant to add what currency it was, i'm using Euro's. I don't edit video much, I do take photos as a hobby. Also i wouldn't mind having the possibility of streaming also.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374018
Are you looking for a single monitor? If so, I would recommend taking a look at some 1080p ultra wide monitors that are high refreshrate if that is in your budget, otherwise you could take a look at just normal high refreshrate monitors that will provide a smoother gaming experience.. Also, if you are looking to stream, I would recommend taking a look at Ryzen 5 CPUs if you are willing to consider AMD.
Edited by rmathiasen
Added high refresh rate recomendation.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374046
need OS/monitor? 17 countries use the euro, be specific.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374047
i have a pcpartpicker list incoming, it is just loading really slowly in between adding parts
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374098
I would be looking for something with a high refresh rate but that would be further down the line. Just need to get the machine built first. I've never used a AMD proc before and no less about them then i do about Intel.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374107
5 minutes ago, Some Random Member said:
If you want to stream comfortably then it would be recommended to look at either the r5 2600 (the best budget option) or the more expensive i7 8700. Then for the gpu you could go with the gtx 1060,also an asus mobo, 16gb of ram and a 2tb hdd, 250gb ssd.
i thought of a build like this before but isn't it really expensive ?
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374115
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374128
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  (€215.98 @ Custompcparts)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (€79.10 @ Custompcparts)
Memory: Kingston - FURY 16GB (2 x 8GB) DDR4-2666 Memory  (€178.95 @ Komplett)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (€80.12 @ Custompcparts)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€66.17 @ Custompcparts)
Video Card: Palit - GeForce GTX 1070 Ti 8GB Dual Video Card  (€557.60 @ Custompcparts)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  (€50.54 @ Custompcparts)
Power Supply: be quiet! - Pure Power 10 400W 80+ Silver Certified ATX Power Supply  (€65.40 @ Custompcparts)
Total: €1293.86
Generated by PCPartPicker 2018-05-24 16:35 IST+0100
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374135
Total: €1293.86
cheers buddy i'll take a look through it.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374141
You can buy that monitor on a german shop (I'm from spain and I buyed that monitor but 24 inch from germany )
https://www.alternate.de/html/product/1294352
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374147
And in spain there is a good store that sells like KM 0 cars but with pc's 1 year warranty and cheap , i dont know if they ship to ireland but worth a try
https://www.pcmontajes.com/ofertas-unicas/1941-danko-i7-6700k-16gb-ssd120gb-m2-1tb-gtx1060-6gb.html
Edit : I bought my pc there and my gf (I founded there a 1060 strixx for 300 euros on that store, so look at "ofertas unicas" section )
https://linustechtips.com/topic/930318-my-first-build/#findComment-11374167
