1080p 120hz or 1440p 120hz monitor?
babadoctor
Should I buy 1080p 120hz monitor or 1440p 120hz monitor?
I have a 1070 and i7 8700k, can my gpu handle the 1440p monitor?
I wanted something under 250$, and I found this
https://www.newegg.com/Product/Product.aspx?item=N82E16824267006
But it's AMD Freesync, so im not sure if it will be okay or not
any recommendations?
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
your gpu *should* be able to handle it. as for freesync, i don't think it will affect anything?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
I would go with a 1440p personally, and don't worry about the FreeSync - I have a XF270HU which is a 144hz 1440p w/ FreeSync but I'm running a 1080Ti (I didnt feel like shelling out for GSync).   I'm actually thinking of moving up to 4k, but need to find a panel that's good for work (photo & video editing and play)
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Logitech G Pro x Superlight
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
