VRM overheating?
Solved by HunterAP,
So some development happened:
- Turns out the VRM's were overheating because the "auto" settings for some parts of the CPU voltage controls were overvolting those parts (note that this "auto" setting is the default option and apparently isn't good at actually doing what the name implies). I forcibly lowered them to what the "default" speeds were and the issues are gone.
- I managed to raise the OC to 4.6GHz and still hit ~62c on the CPU under an extended Aida64 CPU Stress Test.
TL;DR thanks MSI for bad auto settings in the mobo.
