Do you have a second system to try it in?
Is your power supply sufficient?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/929135-390-on-x79-do-not-work/#findComment-11362688
1 hour ago, jpwk said:
I bought an second hand XFX 390 4G yesterday,replacing my broken graphic card,but it can not pass the self test,the fans works well,can anybody help me?my mother board is Gigabyte  X79-UD5
Reset the BIOS.
Goto BIOS (maybe with another Card), look for PCIe Gen and set it to Gen 2.
The X79 Plattform wasn't really designed for PCIe 3.0, that was more of an afterthought and introduced with the 4820 and 4900 series aka Ivy-E.
Sandy Bridge-E does not have official PCIe 3.0 Support. Inofficially it works with some cards but not all (causes Problems with nVidia Kepler Series Cards)...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/929135-390-on-x79-do-not-work/#findComment-11362765
4 minutes ago, Stefan Payne said:
Reset the BIOS.
thanks for your suggestion, I will try it immediately
https://linustechtips.com/topic/929135-390-on-x79-do-not-work/#findComment-11362779
