need help
Go to solution Solved by BrandonKHarris,
Just now, nancke said:
just wanna get into streaming but need a pc first,
i think i will go whith the cheep to start and then hust upgrade later
the screen and stuff dosent seem that bad if you can se what it is even tho its in danish
thats what im saying get the cheap one first
https://linustechtips.com/topic/929070-need-help/#findComment-11362000
