Hello everyone. My computer:
Gigabyte GA-Z77M
i5 3750K
1x GTX 970 G1 Gaming
4GB Ram DDR3
2x HDD (1x 1TB and 1x 500GB)
Cougar GX 800w
Ultrawide Monitor 2560x1080
Windows 10
and it started giving up, first it was 2 ram slots, then the BIOS wouldn't work, and now one more ram slot stopped working, which left me with only 4gb of ram max. I didn't find any compatible mobo where I live (Brazil), so I want to upgrade it.
I play games, edit videos and also am a game designer, that's why I think Ryzen 5 will be more suitable. I dont have a big budget and am in doubt between motherboards. I will list all the parts I'm thinking of getting:
AMD Ryzen 5 2600 3.4GHz
HyperX FURY 8GB 2400Mhz DDR4
GA-AB350M-Gaming 3 / PRIME B350M-A
GA-AB350M-Gaming 3 cost around 35$ more.
Is it a good build?  Which Motherboard should I get?
Thanks in advance.
https://linustechtips.com/topic/928717-help-with-necessary-upgrade/
Gigabyte GA-Z77M
i5 3750K
4GB Ram DDR3
Cougar GX 800w
Windows 10
Thanks in advance.
Are you certain your power supply is good? A failing power supply can cause all manner of problems...
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Are you planning on OCing?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
It's new and I tested everything, I'm sure it is ok.
Yes, I play to OC in the future if needed.
That 1 stick of memory? Ryzen loves high bandwidth on its RAM, so use kits with multiple sticks at least, and go after high frequency ones if budget allows.
Both motherboard are kinda bad, though the Prime B350M-A is even worse (Mosfets overheating problems on both boards). While the Gaming 3 should be fine with a CPU at stock speeds with its small VRM heatsink, the B350M-A is likely to not do it. There is no heatsink at all
Desktop benching:
Get a better motherboard then. Those are both so-so b350 boards.
See if you can find a pro4, prime plus, or b350-f gaming.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
