Zalman Z11 Fan Filter.
Luke
Just a heads up to anyone that owns a Zalman Z11 or is looking to buy one, You do NOT need to remove the front panel to replace the front fan or clean the filter. I spent a long time searching for a case to buy when i was on a budget and in many reviews the reviewers complained about how you had to remove the front panel to clean the filter or replace the fan and how hard it was to do so.
There are four little tabs on the cover that i pushed on with a screw driver to remove it. I filed down the plastic on the tabs to make it easier to remove in the future but that's just preference.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
