The fan on my stock AMD heatsink decided today would be a good day to die. I don't want to spend more than $18 and found this. Is this a good enough cooler until I build my new system? It appears to be good but I've never had experience with Zalman. Could I possibly be an improvement over the stock cooler? thanks.
Edit: The fan only lasted 2668 hours :(
https://linustechtips.com/topic/92847-emergency-replacement/
It should be fine, just DON'T OVERCLOCK It probably wont be much of an improvement if any
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/92847-emergency-replacement/#findComment-1249990
I won't over clock it, I never have never will, I just need it to run.
It will run well enough
https://linustechtips.com/topic/92847-emergency-replacement/#findComment-1250001
It should run perfectly fine.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/92847-emergency-replacement/#findComment-1250006
Cm hyper 212 (evo, plus, what ever they re all the same)can be had for 20$ ish and is about the best budget cooler you can ever get, it s cooling power is close to 80$ noctuas, albeit louder...
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/92847-emergency-replacement/#findComment-1250097
