Hi, Im currently troubleshooting my PC, It's currently not booting, no signs of life (no lights, fans does not spin even the fan of the psu doesnt spin) how ever I've tried using the same psu to different motherboard and it worked.
I suspect that my mobo was reset and brought back to 6th gen bios, now my question is what will happen if you insert a 7th gen procie to a 6th gen(bios) mobo?
8gb gskills ram
i5 7400
msi h110m pro-vh
https://linustechtips.com/topic/928462-need-help/
It wont display anything, but fans and lights should still work.
That said, this thing does not have a backup BIOS chip on board, so the chance of a reset causing it to roll back to 6th gen only BIOS is very low. Since the PSU is tested, my guess will be a broken motherboard.
Desktop benching:
https://linustechtips.com/topic/928462-need-help/#findComment-11357126
I see, thanks. kinda sucks, this mobo just lasted less than a year.
https://linustechtips.com/topic/928462-need-help/#findComment-11357129
