CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.69 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($164.99 @ Newegg)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive  ($72.27 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($189.00 @ Amazon)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($36.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Total: $798.71
Generated by PCPartPicker 2018-05-18 11:27 EDT-0400
For that budget, I would look at some combo deals that retailers are doing to flush out generation 1 Ryzen stock.
You should be able to get an R5 1600 + B350 based combo for cheap.
If you can net an R7 1700, definitely do it.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
Total: $798.71
Nice list. Almost exactly what I went with. The 1600 is a safer bet probably in terms of B350 compatibility, I only picked the 2600 for the sake of 10 bucks!
I agree.
The OP definitely needs to make sure that the motherboard will come with the latest BIOS out of the box for the 2600 though.
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
The main reason I didn't pick the 2600 was budget. It certainly would be the better choice given the small cost differential. Although motherboard BIOS compatibility must be taken into account.
AMD really needs to get those B450 boards out.
What type of video are you editing  8K 4K 1080 720? What are your run times. What is your production deadlines  Daily Weekly Monthly. Anyways Core count then Video and Ram than Storage Raid 0+1 so your work is safe the rest is candy coating. Dell or Hp will get you a warranty so you will have less down time.  oh and a Display is a must if doing high end stuff
