Custom loop in a Silverstone rvz-03 mini itx case?
Solved by W-L,
4 hours ago, kevinisbeast707 said:Lol I figured I would have to but I didn't know if it'd be easier to cable manage with the Hardline going to the CPU since it'd be rigid tubing that wouldn't move.
once configured soft tube shouldn't flop around, you can get sleeved custom length cables which will probably be a must in such a small system or have original PSU cables that are extremely short with little slack in the length required.
