28 minutes ago, Luke0103 said:
I can’t get into the bios because the keyboard doesn’t work. Or I should say the keyboard does work but because of this problem it won’t work
Remove the CMOS which resets the BIOs than put it back in. Boom, should be solved.
(It's that circle thing, just unplug the PC before you do it)
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
https://linustechtips.com/topic/927803-io-problems/#findComment-11351087
2 minutes ago, Luke0103 said:
Yeah I tried it already and it still doesn’t work. That’s what’s someone else told me when it happened previously but for some reason it doesn’t work this time
Hmm I don't know? What's the model of mobo?
https://linustechtips.com/topic/927803-io-problems/#findComment-11351097
Have you changed any settings within the BIOS recently?
Removing the CMOS battery won't always clear CMOS. Power off the machine, remove the power cable, CMOS battery and get a screwdriver.
At the bottom of your motherboard below the CMOS battery and to the left of the bottom four SATA ports will be two pins sticking out from the motherboard. Hold the screwdriver on top of these for 5 - 10 seconds making sure both are contacted at once.
Remove the screwdriver, reconnect the CMOS battery and plug in the power cable.
Never jump these pins while the system is powered on.
I've highlighted in RED where the pins are, page 7 of your motherboard manual component name JBAT1
https://linustechtips.com/topic/927803-io-problems/#findComment-11351117
Ok so I did exactly what you said and it came up with the reset the bios thing but the USB devices still aren’t working so I can’t press f1 to run setup
https://linustechtips.com/topic/927803-io-problems/#findComment-11351147
2 minutes ago, SethKraota said:
Ok your motherboard supports an older format of keyboard called PS/2. This should work even if USB won't. Assuming you don't have an ancient keyboard lying around you may want to look at eBay or local charity / thrift stores.
I love PS/2 my dad has tons of those. They are so redundant. Many local businesses have them, go ask around. If you can.
https://linustechtips.com/topic/927803-io-problems/#findComment-11351169
1 minute ago, SethKraota said:
My IBM Model M has saved more times that I can comfortably admit.
He has 2 of those ;) I just like old hardware too, lots of old old stuff! Even some Nitrous Oxide cooling lol
https://linustechtips.com/topic/927803-io-problems/#findComment-11351185
