Does the block move off the CPU at all? If it stays in place, then it should be fine.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/927260-help-my-evo-cooler/#findComment-11345733
The 212 Evo can twist a bit when mounted. This is normal.
https://linustechtips.com/topic/927260-help-my-evo-cooler/#findComment-11345735
