Suggested Cooling
Solved by Josh2002,
2 minutes ago, samcool55 said:Well the thing is, if you start to overclock you'll probably end up being thermal limited. Even if you get a decent cooler like an h115i or something similar. If you want the best i would get one from NZXT or Corsair.
Problem is that it's not the fault of the cooler. An 8700k runs quite hot when overclocked. Not much you can do about it.
Personally i have an H100i V2, but i hate it. I'll never get an AIO again. I would just stick with air.
If i was you i would buy the NH-D15, it's not that pretty i agree, but it will perform stupidly good and it will be so quiet it's in a different league than an AIO.
Ok thanks I'll just go with air cooling now.
