I am stuck with how to put in my case fans
Jesse Wood
This is my first build and am really confused about the case fans. The screws that came with the fan a quite a bit bigger than the holes in the case. It this always the case? If not, how do I fix this.
If these screws came with the fans, then they are right.
These fans screws are designed to drill into the plastic casing for tight fit.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
I know the screws have to self tap through the plastic of the fan but it's the holes in the case that are quite a bit smaller
Where on what case? Can you post some photos?
You’re meant to screw the screws in. So the hole will be as big as the gaps in the screw. So the hole looks smaller.
The case is the Silverstone Redline RL06
That is a pic of the screw beside the hole
Those small holes are not for mounting fans. The larger ones above and down are the correct places. Metal part stays between screw head and the fan.
The Tic Tac pill looking slots are the fan mounting holes.
Like said above, you are suppose to use those elongated holes. There are so many of them so you can install different size fans and radiators.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
make sure to draw the air from the front out the back if you want to keep your air moving the same drawing clean air in and if your case has it make sure the air intake has a filter. and clean it regularly.
a note that air pressure will affect how dust free your pc is.
