well thats a splitter. You can connect to it, it will just run the pump at 100% all the time with no control over the RPM.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
yeah i know its a splitter, thats why i bought it at the first place. But the description says 3 pin, but i did not expect this kind of '3 pin'
so my pump will run just fine without the 3rd pin(tach)?
Yes, should work just fine.
Community Standards
"Beast Mode"
Well, since its splitter, it would run pump at speeds set for thing on other header with rpm pin.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Splitters only read the rpm from one header so the 3rd pin isn't needed on the rest and the pwm signal for control is sent on the 4th pin.
