When I started buying parts for this build, it was supposed to be a budget pc. I started with a new ASRock AB350 Pro4 motherboard and a new Ryzen 5 1400 cpu. But then I bought a couple of used windforce 1080's from a coworker who used them for a couple of months in his mining rig. Here's my list of parts that I have now.
ASRock AB350 Pro4
Ryzen 7 1800x
Noctua nh-d15s
Samsung 970 evo 250gb m.2 ssd
Crucial 500 gb SATA ssd
Seagate 3 tb SATA hdd
Gigabyte Windforce Gtx 1080
EVGA Supernova G2 650 watt gold psu
16 gb Gskill 3200 ddr4 ram
Corsair Obsidian 750 full-tower case
Let me know what you guys think. I was told this is a weird build.
https://linustechtips.com/topic/926815-my-first-build/
38 minutes ago, Lil_Kodiac said:
I should probably mention that I'm building this for simultaneous gaming and streaming, until I can build a second pc for dedicated video encoding.
No need for a second pc if you got ryzen. It can handle gaming and streaming
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/926815-my-first-build/#findComment-11341070
ASRock AB350 Pro4
Ryzen 7 1800x
Noctua nh-d15s
Everything looks good except for your motherboard. It's a little more on the budget side. With a 1800x, you should have an x370 board. It will work but you can expect overclocking performance to be not too good
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/926815-my-first-build/#findComment-11341075
a couple of odd part choices, but it's quite far from being a train wreck.
https://linustechtips.com/topic/926815-my-first-build/#findComment-11341080
