Hey guys so im wondering is the pentium g4560 supported right out of the box without a bios update with this board:https://www.amazon.com/GIGABYTE-GA-B250M-DS3H-LGA1151-Intel-Motherboard/dp/B01N2WG23X/ref=sr_1_2?s=electronics&ie=UTF8&qid=1526181820&sr=1-2&keywords=msi+b250&dpID=51vELZeiMML&preST=_SX300_QL70_&dpSrc=srch
and sorry again is it supported with the gtx 1050 2gb model please answer
https://linustechtips.com/topic/926738-motherboard-power/
3 minutes ago, BrandonKHarris said:
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11337398
4 minutes ago, BrandonKHarris said:
Yeah, 200 series boards should work out of the box.
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11337399
2 minutes ago, Alexsolo said:
Definitely, but I would go for a H110, more cost effective same performance when going for a budget Pentium processor.
they are the same price pretty much from what i just saw what is the difference and is there a specific one you are talking about?
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11337499
21 hours ago, Alexsolo said:
H110M-A from Asus is good. I've built a lot of machines with that board.
will it support the pentium g4560 right out of the box with no bios update and will it support the gtx 1050 2gb?
and would it fit in a small machine because i dont know what size the pc is yet havent got it
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11337509
33 minutes ago, Alexsolo said:
Yeah it has a PCIe connector, like any other videocard does. The only difference is the cooler design is more compact and smaller fan/radiator.
does it perform any worse then the normal version? and dont i just have to plug it into the slot?
here is the link to the specific one that im getting because apparently some need them and some just draw from the motherboard slot - https://www.amazon.com/EVGA-GeForce-Support-Graphics-02G-P4-6150-KR/dp/B01M9FD3PC/ref=sr_1_2?ie=UTF8&qid=1526199133&sr=8-2&keywords=gtx+1050+mini&dpID=513kShn8SuL&preST=_SY300_QL70_&dpSrc=srch
i found out it doesnt need any external power its powered by the slot
Hey guys sorry im back again im just a noob lmao but im just checking is this motherboard able to power the gtx 1050 mini just from the slot or do i need a  connector because i just need it to be able to power through the slot im not overclocking or anything until i learn a bit more and shit about it here it is:https://www.amazon.com/GIGABYTE-GA-B250M-DS3H-LGA1151-Intel-Motherboard/dp/B01N2WG23X/ref=sr_1_2?s=electronics&ie=UTF8&qid=1526181820&sr=1-2&keywords=msi+b250&dpID=51vELZeiMML&preST=_SX300_QL70_&dpSrc=srch
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11340290
As long as your GTX1050 doesn't have a PCI-E power connector the motherboard will be able to power it directly as it's per the PCI-E spec.
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11340337
9 minutes ago, airdeano said:
the gtx 1050 is what you'd wanna know about power..
whether it has a 6-pin connector or not. the mobo will only power the PCIe slot, if additional power requirements are needed, the GPU will have another power connection.
i read on the site here are the comments
Does this need 6 pin pcie power?
No external power required.
No. It's powered by the slot.
No. You just plug it into the motherboard.There are no separate power connectors.
theres all the importnat and helpful answers from people
https://www.amazon.com/EVGA-GeForce-Support-Graphics-02G-P4-6150-KR/dp/B01M9FD3PC/ref=sr_1_2?ie=UTF8&qid=1526265673&sr=8-2&keywords=gtx+1050+mini there is the link to the gpu so do you know if the motherboard can power it?
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11340346
3 minutes ago, airdeano said:
and youve answered your own question, yes the mobo will work with that gtx1050
lol thanks its weird because only staff have posted on this topic but anyways thanks for the help
lol nvm im on the wrong topic lmao
https://linustechtips.com/topic/926738-motherboard-power/#findComment-11340360
