so my case only has 2 hard drive bays and  i have 2 2tb hdd's that im gonna run in raid. i have a 1tb hdd and a lot of my applications and games are on this. i want to reuse the hard drive in my dad's pc i just built him.
i was thinking could i put my hard drive in the bottom, not mounted for a few days so i can transfer all of the files. i wasnt sure if it would shake around din the case lol and get damaged xD
Ryzen 5 5600x, GTX 1070 Duel Asus OC Edition, 16gb ram, Asus Tuf Gaming x570-plus
https://linustechtips.com/topic/926290-dangle-my-hard-drive/
only will shake around if you shake it
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/926290-dangle-my-hard-drive/#findComment-11336071
from experience, not mounting hard drives at least "somewhat" secure.. bad idea.
i've totally just double-side-tape'd one on its side in a case that had pretty much no mounting options, but thats the least i'd recommend you do, because hard drives like to "walk away" when working :P
https://linustechtips.com/topic/926290-dangle-my-hard-drive/#findComment-11336102
ill try to secure it as best i can,. maybe in the rats nest at the bootom lol.
https://linustechtips.com/topic/926290-dangle-my-hard-drive/#findComment-11336119
protip: a neoprene anti-vibration mat is dirt cheap, can be cut to size with scissors, and past that all you need is some string :P
https://linustechtips.com/topic/926290-dangle-my-hard-drive/#findComment-11336165
xD maybe, ill see what i cna find as im adding 2 hard drives in raid but need to transfer my files over. was going to transfer them over a coupe of days instead of 1tb in 1 go xD. its not going to be for long just so i can move the files over
https://linustechtips.com/topic/926290-dangle-my-hard-drive/#findComment-11337106
